I am having problems getting atoi to work.
here is how I populate the comin[] array
do { comin[index] = (getchar()); ++index; } while (index<=4);
later in the program I do the following:-
command = atoi(comin);
expecting to get a 4 digit number in command. comin is working fine - no problems. But command is always 0 (zero). I have tried quite a few things, but no luck. I did a search on the forum andd came up with this
http://www.keil.com/forum/docs/thread10470.asp
Anybody else had this problem or know a work around?
"... expecting to get a 4 digit number in command."
Assuming 'index' is 0 upon entry, the loop iterates 5 times.
"But command is always 0 (zero)."
Are you NUL-terminating received digits to make 'comin[]' a proper string or are you relying on some other means of causing atoi() to stop?
Never mind what I said about the loop count.
How atoi() stops is still a valid question.
Dan, I am terminating the string of 4 ASCII chars with a \n. Really strange problem.
If you terminate the array with a '\n', then you do not have a C string. A C string should be terminated with a '\0' which is the character constant corresponding to the numeric value 0.
If you always get the value 0 from atoi(), then your string either contains the numeric string "0" (possibly with an initial whitespace and optional sign) or none of your strings contains anything that may be converted to a number.
Do show the smallest code snippet that shows an incorrect (in your view) return value from atoi(), so we can see what you are doing wrong.
Another point here is how do you know that the value is always 0?
If you are printing it out then remember it is an "int" value returned by ATOI and you need to use the correct print format as it is possible to get silly print values with other formats.
As for the discussion about when ATOI stops, it is clear in the function description that it stops as soon as it encounters a non numeric character (I guess it applies ISDIGIT or something similar). This means a \n should work although is not really preferable over a \0 as described earlier as this is a proper C string terminator.
I use ATOI quite a lot on an 89C51 and it works fine for me.
Cheers,
Dirk
Dirk/Per, thanks for the feedback. I will take look a bit later tomorrow - I am out on business at the moment.
Cheers Jason
hi, today I did some more work on this problem.
1. I corrected the serial routine to collect chars 1 by 1 2. If i look at comin, command and index using the simulator I can see that index is incrementing, comin is collecting the chars (I'm putting in the ascii codes, so i.e. digit '9' is 57decimal 3. the reason atoi is not working is my code never goes through the atoi segment of the code - it always jumps over it. 4. I experimented and removed the if statement and braces arounf th e aoi statement and atoi is working. 5. The problem is my if statement . . .
I have to admit I am stumped at this point.
here is the serial input routine
void uart_rx_isr (void) interrupt 4 using 3 { if (RI==TRUE) /* if RI is set then execute the RxD routine, else jump over and exit*/ { comin[index] = SBUF; // I tried (getchar()) which also works ++index; RI = FALSE; /* clear the RI interrupt flag and exit */ } }
here is the fragment that contains the atoi
loop: /* this is the main process loop - it services pushbutton and */ /* rotary encoder inputs as well as th e inputs from the remote */ if (comin[5]=="\n") //if (index==6) can also be used here, but I prefer the \n or some other command string termiator { command = atoi(comin); txprocess(); // go and process the command index=0; } command = 0; /* now flush command and comin */ goto loop; }
Note that "\n" is a C string. The value of the C string is the address of the first character in the string.
What you want to do is to compare characters, so you should use a character constant.
if (comin[5] == '\n') { ... }
Notice the difference between single and double quotes.
If this
if (comin[5]=="\n")
ever compiled without throwing a warning into your face, you run the compiler at an insufficiently high warning level.
Not even to mention you absolutely neet to get yourself a LINT tool and start using it. Now!
It is a common assumption that warnings can be ignored - anything that creates a binary should be good to go.
Well, I don't have to tell you, Per, but for the record: most of the time, using sensible tools, that assumption is wrong. Especially so if the person doing the ignoring doesn't know enough C to even understand the warnings' meaning.
Only if you're sure you could explain convincingly to both your grandma and your boss why exactly you're getting this particular warning about this particular piece of code, and why it's harmless in this particular case, you can ignore it. Actually in that case you may even go ahead and disable it for this particular case, if the tools have sufficiently fine-grained control over warnings. That's one reason why LINT is more important than the C compiler in the business of checking warnings: its warnings have the finest controls you're likely to find in any tool.
The atoi statement is wroking now - thank you. I have mad e similar errors in other sections of the code - these are also fixed now.
Jason
Yes, I did get warnings about 'statements that do nothing' but these warnings were for two while (1) statements, not for the atoi statement detailed above.
I have the warning level set to the highest in the compiler.
Do have a recomendation for a lint program?
PC-Lint from Gimpel Software. Bradford
I am using version 9. An occasional life saver.
Ok I will give it a try.
