SWI switches to interrupt
I have problemm with critical sections again :(
When I execute vEnterCritical or vExitCritical step by step they works well.
When I step over this functions they switches CPU to interrupt mode... I can't understand such mess.
Here is my code
volatile unsigned int uiCriticalNesting = 0;
extern "C" void __SWI_0 ( void );
extern "C" void __SWI_1 ( void );
void __swi(0) vEnterCritical( void );
        int R12;
        __asm{ MRS      R12, SPSR               };
        __asm{ ORR      R12, R12, #0xC0 };
        __asm{ MSR      SPSR_CXSF, R12  };
        ++uiCriticalNesting;
void __swi(1) vExitCritical( void );
        if( uiCriticalNesting )
                --uiCriticalNesting;
                if( uiCriticalNesting == 0 )
                        int R12;
                        __asm{ BIC      R12, R12, #0xC0 };
and:
T_Bit                   EQU     0x20
                                PRESERVE8                                               ; 8-Byte aligned Stack
                                AREA    SWI_Area, CODE, READONLY
                                ARM
                                EXPORT  SWI_Handler
SWI_Handler
                                STMFD   SP!, {R8, LR}                   ; Store R8, LR
                                MRS     R12, SPSR                               ; Get SPSR
                                TST     R12, #T_Bit                     ; Check Thumb Bit
                                LDRNEH  R12, [LR,#-2]                   ; Thumb: Load Halfword
                                BICNE   R12, R12, #0xFF00               ;               Extract SWI Number
                                LDREQ   R12, [LR,#-4]                   ; ARM:  Load Word
                                BICEQ   R12, R12, #0xFF000000   ;               Extract SWI Number
                                LDR     R8, SWI_Count
                                CMP     R12, R8
                                BHS     SWI_Dead                                ; Overflow
                                ADR     R8, SWI_Table
                                LDR     R12, [R8,R12,LSL #2]    ; Load SWI Function Address
                                MOV     LR, PC                                  ; Return Address
                                BX              R12                                             ; Call SWI Function
                                LDMFD   SP!, {R8, PC}^                  ; Restore R8 and Return
SWI_Dead                B               SWI_Dead                                ; None Existing SWI
SWI_Cnt                 EQU    (SWI_End-SWI_Table)/4
SWI_Count               DCD     SWI_Cnt
                                IMPORT  __SWI_0
                                IMPORT  __SWI_1
SWI_Table
                                DCD     __SWI_0                                 ; SWI 0 Function Entry
                                DCD     __SWI_1                                 ; SWI 1 Function Entry
SWI_End
                                END
It worked for a months... Now it stopped working.
Can anybody help?
