Low Power on STM32 wakeup pin
I'm trying to make our product to go into any of the low power modes of the STM32 microcontroller. That part of the code works, only I can't get the microcontroller to wake-up on the wake-up pin (PA.0). According to the datasheet the only requirement is that the pin is enabled in the 'Power control/status register (PWR_CSR)'. I've made a simple program on a development board STM3210B-EVAL. There the wake-up pin also doesn't wake the microcontroller. I've tried to use the standby example wich is supplied with the STM library, and it also will not wake-up the microcontroller.
The following code is the way I go into standby.
PWR_WakeUpPinCmd(ENABLE);
PWR_EnterSTANDBYMode();
What can be the reason that the microcontroller doesn't exit the low power modes with the wake-up pin?
  • As this is a question specifically about the operation of a particular microcontroller - not a Keil product - you would probably be best to ask in the manufacturer's device-specific forum.
    If you do cross-post, be sure to make it clear and include links between the threads!
    Note that there has been much discussion about STM32 low-power modes already on ST's STM32 forum - so you should start by reviewing that...
    my.st.com/.../AllItems.aspx
