Removing comments from source code changes *.o, *.map, *.axf files
Compiling for STM32F103CB using Keil MDK-ARM v4.10
This is proving to be a major pain this afternoon, but we have discovered a crazy bug in the Keil compiler.
If we remove some comments (e.g. "//This is a comment") from a file within the source code then we see differences in the .map files, the .o object files and also the .axf file.
This seems to get worse if I change the optimization settings from -o0 to -03.
Any chance that the tool is actually at fault here, or am I going mad?
Many thanks,
Stephen Ormston.
  • Well, *.o files contain debugging information which could be sensitive to source code changes (I don't know this for a fact, pure speculation.) Same about *.axf. Not sure about *.map files. Also you should not forget about the linker->compiler feedback mechanism for elimination of unused functions. This mechanism can lead to different program images in consecutive builds. It should stabilize after second consecutive build, though.
