I'm using the MCBSTM32E board with STM32F103ZE uC.
If I declare an enumeration type as 'static' in a function or as a global variable then the compiler signals no error or warning but the application simply does not run.
typedef enum{ first=1, second=2 }TeMyEnum; void vMyFunc(){ static TeMyEnum eMyEnum=second; }
Where do I go wrong?
Thanks Henk
