a51 %1.a51 DEBUG >C:\trash c51 %1.c DEBUG CD >C:\trash BL51 F3Rstart.obj, F3Rmain.obj, F3Riic.obj, F3Rtemp.obj, F3Rxxx.obj to f3rtc.omf RAMSIZE(256) >trash
the above are actual commands extracted from a .bat when I make the job there is no linkage to C source if I make a 'synthectic' main in assembler there is linkage to it "the first place you go blind is on the eyes" what is it I can't see?
PS removing 'CD' makes no difference
well, the famous "between a rock and a hard place" = "between Keil and SIlabs" hit again. when you include OBJECTEXTEND the debugger craps out in any watch.
I have informed both Keil and SILabs support, let's see what happens
solved, need 'OBJECTEXTEND' added. no such in the ducumentation
'linkage' above may be better known as 'address correlation for line ...' when trying to set a breakpoint in the source
