AREA Directive problem in ARM LPC2148
Hi all,
I am making some small programs in ARM assembly language.
I am using KEIL software for the programming and compialtion.
The problem I am facing is during a program in which data form one memory is copied to another memory.
The example I am following is given in the help file with KEIL uvision.
The Program is as follows :
AREA Word, CODE, READONLY ; name this block of code
num EQU 20 ; set number of words to be copied
ENTRY ; mark the first instruction called
EXPORT __main
__main
LDR r0, =src ; r0 = pointer to source block
LDR r1, =dst ; r1 = pointer to destination block
MOV r2, #num ; r2 = number of words to copy
wordcopy
LDR r3, [r0], #4 ; load a word from the source and
STR r3, [r1], #4 ; store it to the destination
SUBS r2, r2, #1 ; decrement the counter
BNE wordcopy ; ... copy more
stop
MOV r0, #0x18 ; angel_SWIreason_ReportException
LDR r1, =0x20026 ; ADP_Stopped_ApplicationExit
SVC #0x123456 ; ARM semihosting (formerly SWI)
AREA BlockData, DATA, READWRITE
src DCD 1,2,3,4,5,6,7,8,1,2,3,4,5,6,7,8,1,2,3,4
dst DCD 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
END
The Problem is data is not copied in the destination address nor I can read the data from the source.
As I am using KEIL so there is Startup.s file and I have commented the last part in the file which is :
; Enter the C code
IMPORT __main
LDR R0, =__main
BX R0
; IF :DEF:__MICROLIB
; ; EXPORT __heap_base
; EXPORT __heap_limit
; ELSE
; User Initial Stack & Heap
; AREA |.text|, CODE, READONLY
; IMPORT __use_two_region_memory
; EXPORT __user_initial_stackheap
;__user_initial_stackheap
; LDR R0, = Heap_Mem
; LDR R1, =(Stack_Mem + USR_Stack_Size)
; LDR R2, = (Heap_Mem + Heap_Size)
; LDR R3, = Stack_Mem
; BX LR
; ENDIF
and thats why I had used EXPORT __main in the starting of the progam.
Could any one please tell me what the problem is and where I am doing the mistakes.
As I am new to arm assembly ... so cant figure it out
regards
Arvind
