Flash initialization error with F41X
Hi:
I have a device with an 8051F410 which uses C2 protocol to connect. I am using a USB Debug adapter in the Silabs IDE with a full Keil Compiler (all of this new within the last month) I can connect, erase memory, look at the RAM, etc. but when I try to download the code, it all seems to work fine, but at the end gives me the flash initialization error and says that the download failed. Someone said that I must have fried the chip, so I went out and bought from SiLabs their F411 Voice recorder board. Again, I could connect, erase, and see ram with C2, but I can not download the code due to the same flash error message. The IDE can't seem to find the 411 VR board if I try to use JTAG.
Any ideas on how to fix this... what my mistake has been?
Thanks,
Wes
