Hi, I have 2 questions regarding SROM that I couldn't find the answer to.
1) If the compiler adds LCALLs to c lib (?C?..) functions in the code I am copying to the ram are the c lib functions located in this segment as well and are copied to the RAM or are they still called from the flash?
2) Dows the linker know to locate global/local variables that are used from this function in a RAM area that isn't overlapping with the are I'm about to copy the code into or must I locate all variables manually in a non-oberlapping area of of the RAM?
Thank you
... it's sooooo overrated.
