Hello, i work with uVision 3 V3.72, linker V3.1.0.942. i check in linker options make ro section postion independent and also use memory layout from the Target dialog.And duing linking shows warnign L6914W: option ropi ignored when using --scatter. My question is why? Why this warning has appeared? Is there any other why to make section position independent? thanks in advance
Position-independant code requires the memory addresses to be relative.
A scatter file allows multiple memory areas to be specified.
Position-independant code would not manage that you move one memory area but keeps the other fixed since that would change the relative distance.
In the end, you will really have to think twice about your memory layout and use of global variables or pointers with hard-coded destination when working with position-independant code.
Moving the code to a 4kB higher address may not mean that you want all variable references to also move to a 4kB higher address...
I believe this answer gives some information but i want to know how to make my position independent. i just want my program to work independently to any adress.i want the same program to work if i will load it to any area without making any changes to linker.
But you still did not give any information about whatyou consider "position independent". If the code moves to a 1kB higher address - what about global variables? Should they also move or stay fixed?
After a compilation appears a bin file. i want this bin file using a bootloader to put at any address. It must work properly if bootloader will put it at addres 0x100000 or at addres 0x110000.So the code must be position independent.
