i am a noob and learning 8051 coding. i want to know how can i use PWM to write a speaker which can emit diff sound (do,re,mi,etc.) by using 2 pins only. thanks.
HI.
the page from master neil is good.
look at the para "Choosing a suitable NPN transistor"
u can simly have the speeker for the load.
Always yo're freind.
Zeusti.
This has nothing to do with the 8051 or Keil tools.
You need some books on basic electronics!
eg, www.kpsec.freeuk.com/trancirc.htm
thanks all very much. i can now handle the software part of my purpose, but for the hardware, i've got some difficulty. i dont know how to amplify the sound of the 8ohm speaker. should i use any op-amp? or it can be done by varying the voltage?
you are write. sorry.
so so many things to do here!
Zeusti,
I'll make no comments about your comments, but I noticed a little error in your code:
;=================================================== ; ; Name : DoNote ; ; Purpose : Produce a sound on P1.0 ; ; Parameters : int Cycles (R6:R7) ; unsigned char Delay (R5) ; ; Result : void ; ;=================================================== ?PR?DoNote?sound segment code rseg ?PR?DoNote?sound DoNote: clr a ; Get 0-'Cycles' clr c ; Bcoz code uses up counter subb a,r7 ; And store to dptr mov dpl,a clr a subb a,r6 mov dph,a ; mov dpl,a <<< I think this should not be here Dn_1: cpl p1.0 ; Toggle the port pin mov a,r5 ; Get 'Delay' mov r2,a ; Loop for 'Delay' djnz R2,$ inc dptr ; Update cycle counter mov a,dpl ; While count is not overflowed or a,dph jnz Dn_1 ; Loop ret
two many things to do here!
extern void DoNote ( int Cycles, char delay ); void foo ( void ) { DoNote ( 10000, 10 ); }
i no people will complain bout my style but here is code with my comments
;=================================================== ; ; Name : DoNote ; ; Purpose : Produce a sound on P1.0 ; ; Parameters : int Cycles (R6:R7) ; unsigned char Delay (R5) ; ; Result : void ; ;=================================================== ?PR?DoNote?sound segment code rseg ?PR?DoNote?sound DoNote: clr a ; Get 0-'Cycles' clr c ; Bcoz code uses up counter subb a,r7 ; And store to dptr mov dpl,a clr a subb a,r6 mov dph,a mov dpl,a Dn_1: cpl p1.0 ; Toggle the port pin mov a,r5 ; Get 'Delay' mov r2,a ; Loop for 'Delay' djnz R2,$ inc dptr ; Update cycle counter mov a,dpl ; While count is not overflowed or a,dph jnz Dn_1 ; Loop ret
in yo're c do this
extern void DoNote ( int Cycles, char delay ); void DoNote ( void ) { DoNote ( }
so there is a donation more than others.
his 'advice' has always been questionable, now his English(?) is unreadable as well.
who can, even in their wildes imagination, believe that a noob will, in any minuscule way, understand uncommented scribbles?
u r write. it is a prototype for the asm function. u put in c and call in c.
Zeusti
sound(int Cycles, char delay); this isn't asm code, how to call this function? or is it useful for the prog.?
if u use a (example 8 ohm) speeker u will need a drivor, ieg a transistor and stuff.
u can use a piezo. won pin on p1.0 and won on ov.
thanks you very much, i also want to ask how to connect the speaker to the 8051? +ve to the p1.0, and the -ve to the gnd? any other components needed?
sorry but got last a bit wrong :(
sound(int Cycles, char delay); sound: mov dph,r6 mov dpl,r7 loop: cpl p1.0 mov a,r5 mov r2,a djnz R2,$ inc dptr mov a,dpl mov b,dph jnz loop ret
here is start. make sound with p1.0. u must improv
call using sound(int Cycles, char delay); sound: mov dph,r6 mov dpl,r7 loop: cpl p1.0 mov a,r5 mov r2,a djnz R2,$ clr P1.0 mov r2,#10 djnz R2,$ inc dptr mov a,dpl mov b,dph jnz loop ret
