Rtl os_tsk_create_ex and c++
i am using the Arm RL-RTX. Creating a task with os_tsk_create(...) works correctly in C, but calling the same function from C++ (.cpp file) gives me the following Error message:
error: #167: argument of type "void (*)(int *)" is incompatible with parameter of type "void (*)(void *) C"
Here is the example code.
#include <RTL.h>
__task void TaskWithParams (int *argv);
void Test(void)
        int param[2] = {111, 222};
        os_tsk_create_ex (TaskWithParams, 2,  ¶m[2]);
Thanks in advance!
