I am an engg student workin on my final year project. I have designed an ARM based audio media player.... Can someone tell me how interface ARM based audio media player with mobiles and pda's.
What, exactly, do you mean by "interface" here?
What role(s) do you requires the Mobiles (phones?) and PDAs to play?
It basically the different ways by which i can implement the "arm based audio media player" on mobiles and pda's...or wat needs to be done so that this media player can work on mobiles and pda's....thanks
"Implement on" is very different from "Interface to"
I think you need to explain precisely what it is that you have actually designed...
It sounds more like a software media player written in ARM assembler, and a request how to port this code base to make different ARM-based platforms use the media player.
An excellent way to make the clock ticking without receiving good answers is to write a help request with too little information to enable people to understand exactly what the problem is, and in what direction a possible solution is expected to be aimed.
