Hello everybody,
I use the ULINK2 with the MCBSTM32 board. I use RTX Kernel too. I would like to use the RTX Kernel event viewer. I have configured the ITM Stimulus port and enabled the Trace with the right core clock. The problem is when i click on "Peripheral->RTX Kernel", it comes an Error "insufficient debug information".
I hope someone had the same problem and solved it.
Thank for your reply.
Hello!
I've absolutely the same problem with my AT91SAM7X-EK board. But it was working a time ago!
Currently I have installed: KEIL MDK-ARM RealView Microcontroller Kit 3_20 KEIL RL-ARM Real-Time Library 3_50
Maybe the updates killed the function we miss now or we just face a resource problem at the target side.
Any helpful ideas are welcome!!
Regards Helmut
Hi Helmut, I have found the solution about this problem. In fact, before RTX it was ARTX. So the solution is to have the same version of MDK-ARM and RL-ARM. I have installed MDK-ARM and RL-ARM v3.70, and it runs well. You can download keil MDK at: www.antycipftp.com/.../ You have to uninstall correctly the software like this tutorial: www.keil.com/.../license_sul_uninstall.htm
Regards Sebastien
Hi Sebastien,
thanks a lot for your immediately reply and HELP!! Unfurtunality our license of the MDK-ARM is already expired and I'm fixed (until the company will sign for a further license) to version 3.20
I just replaced the old version of \KEIL\ARM\BIN\ARTXARM.dll with the new one provided within MDK-ARM 3.70.
Now the RTX event viewer is working again!!
I just wonder why KEIL releases updates of RL-ARM that installs without ANY warnings and kills functions of the MDK-ARM. Also a still active license of RL-ARM will not enable you to install a MDK-ARM that fixes the problem your active license of RL-ARM involved...
Thanks to YOUR help I'll continue working on my project just now without beeing always nervous about may task stack usage and other RTX details!
Thanks a lot!!!
Best Regards Helmut
