uVision3 Bug?
why is the simple code below assembled wrong?
The disassembly copies the same value from the same memory location 0x06 to tp(n). (MOV @R0,0x06)
Thanks for Help
Christian Tauschek
MY WRITTEN CODE:
unsigned char tp[20];
for (n = 19; n > 0 ; n--) { tp[n] = tp[n-1]; }
__________________________________________
WRONG DISASSEMBLY:
46: for (n = 19; n > 0 ; n--) {
C:0x08CA 7F13 MOV R7,#0x13
47: tp[n] = tp[n-1];
C:0x08CC 7421 MOV A,#0x21
C:0x08CE 2F ADD A,R7
C:0x08CF F8 MOV R0,A
C:0x08D0 E6 MOV A,@R0
C:0x08D1 FE MOV R6,A
C:0x08D2 7422 MOV A,#tp(0x22)
C:0x08D4 2F ADD A,R7
C:0x08D5 F8 MOV R0,A
C:0x08D6 A606 MOV @R0,0x06
48: }
C:0x08D8 DFF2 DJNZ R7,C:08CC
MY uVISION3:
IDE-Version:
µVision3 V3.80
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
License Information:
Christian Tauschek
Tauschek
LIC=----
Tool Version Numbers:
Toolchain: PK51 Prof. Develpers Kit Version: 8.18
Toolchain Path: C:\Keil\C51\BIN\
C Compiler: C51.Exe V8.18
Assembler: A51.Exe V8.01
Linker/Locator: BL51.Exe V6.20
Librarian: LIB51.Exe V4.24
Hex Converter: OH51.Exe V2.6
CPU DLL: S8051.DLL V3.65
Dialog DLL: DP51.DLL V2.54
  • why is the simple code below assembled wrong?
    Because it isn't. There's nothing wrong with that code. Dan already told you why:
    Memory location 0x06 is the location of (the bank 0 rendition of) the R6 register, so there is nothing wrong with this: it copies the content of R6 (which at this moment holds tp[n-1]) to where R0 currently points (tp[n])
    So whatever the actual problem is, this code snippet is not it.
