software development for nRF24LE1
Hi
I have bought your nRF24LE1 development kit along with nRFgo starter kit.
I am using this kit for developing a wireless application. My project involves the following things
I need to convert analog signals to digital and transmit them to the receiver.
At the receiver the data is received and is sent to a serial port so that it can be connected to a computer to view the signals transmitted.
I have developed programs for the transmitter and the receiver using the SDK provided with the kit. But I dont know whether there is a transmission or not.
I am using the keil compiler for program development and nRFstudio for flashing the microcontroller.
I am attaching the codes I have written. Please take a look at them and tell me what is wrong with them.
this is the program for the transmitter side
#include <Nordic\reg24le1.h>
#include <stdint.h>
#include "hal_adc.h"
#include "hal_nrf.h"
#include "hal_nrf_hw.h"
code const uint8_t address[HAL_NRF_AW_5BYTES] = {0x22,0x33,0x44,0x55,0x01};
void radio_int(void);
void main()
{ uint8_t xdata rf_payload[1];
hal_adc_set_input_channel(HAL_ADC_INP_AIN1); //selecting channel 1
hal_adc_set_reference(HAL_ADC_REF_VDD); // reference VDD
// hal_adc_set_input_mode(HAL_ADC_DIFF_AIN2); // differential input
hal_adc_set_conversion_mode(HAL_ADC_CONTINOUS); //continuous conversion mode
hal_adc_set_sampling_rate(HAL_ADC_2KSPS); //sampling rate
hal_adc_set_acq_window(HAL_ADC_AQW_12US);//acquistion time
hal_adc_set_resolution(HAL_ADC_RES_8BIT); //resolution
hal_adc_set_data_just(HAL_ADC_JUST_RIGHT);//Justification
RFCKEN = 1;
RF = 1;
EA = 1;
CE_LOW();
while(1)
{ hal_adc_start();
while(hal_adc_busy());
rf_payload[0] = hal_adc_read_LSB();
//rf_payload[1] = hal_adc_read_LSB();
hal_nrf_write_tx_payload(rf_payload, 1);
CE_PULSE();
delay_10ms();
{ hal_nrf_enable_ack_payload(true); // Enable dynamic ack
hal_nrf_enable_dynamic_payload(true); // Enable dynamic payload
hal_nrf_setup_dynamic_payload(0xFF); // All pipes uses dynamic ack.
hal_nrf_close_pipe(HAL_NRF_ALL); // First close all radio pipes
// Pipe 0 and 1 open by default
hal_nrf_open_pipe(HAL_NRF_PIPE0, true); // Open pipe0, with autoack
hal_nrf_set_crc_mode(HAL_NRF_CRC_16BIT); // Operates in 16bits CRC mode
hal_nrf_set_auto_retr(15, 250); // 250 µs delay, 15 retransmits
hal_nrf_set_address_width(HAL_NRF_AW_5BYTES); // 5 bytes address width
hal_nrf_set_address(HAL_NRF_TX, address); // Set device's addresses
hal_nrf_set_address(HAL_NRF_PIPE0, address); // Pipe0 used for auto ACK
hal_nrf_set_operation_mode(HAL_NRF_PTX);
hal_nrf_set_power_mode(HAL_NRF_PWR_UP);
hal_nrf_set_output_power(HAL_NRF_0DBM);
hal_nrf_set_rf_channel(40);
hal_nrf_set_datarate(HAL_NRF_1MBPS);
} void rf_irq() interrupt 0//INTERRUPT_RFIRQ
{ hal_nrf_get_clear_irq_flags();
program for the receiver
#include <stdint.h>
#include "hal_uart.h"
uint8_t rf_status;
uint8_t temp_data;
bool hal_nrf_tx_complete(void);
void main()
RFCKEN = 1;
RF = 1;
EA = 1;
hal_uart_init(UART_BAUD_9K6);
CE_LOW(); // Disable radio
hal_nrf_set_operation_mode(HAL_NRF_PRX);
hal_nrf_set_rx_payload_width(HAL_NRF_PIPE0, 1);
RFCE = 1;
while(1)
void rf_irq() interrupt 2
{ rf_status = hal_nrf_get_clear_irq_flags();
switch( rf_status )
{ case (1<<HAL_NRF_RX_DR):
hal_nrf_read_rx_payload(rf_payload);
temp_data = rf_payload[0];
P0DIR = 0xDF;
hal_uart_putchar(temp_data);
if(hal_nrf_tx_complete())
{ TI0 = 0;
} break;
case (1<<HAL_NRF_TX_DS):
break;
case (1<<HAL_NRF_MAX_RT):
break;
