I have some Const array tables that i want place in the flash/code memory of ARM controller. we can place array in code memory of C51 using "code" keyword. but how to place const array in ARM?
const unsigned char boot_version_string[16] __attribute__( (at(BOOTLOADER_TOKEN_ADDR) ) ) ="FEMBOOT 1.8";
Thankyou Tamir,
__attribute__( (at(BOOTLOADER_TOKEN_ADDR) ) ) keyword will work for 1 or 2 const arrays. but I want to place approximately 50 const arrays of different sizes, do i have to give address to all the arrays individually? Is there any way in which the compiler picks the address automatically?
Note that it's not the Compiler that picks addresses; it's the Linker - therefore, you need to be looking in the Linker Manual...
