hi, I have written code that generate Interrupt on Timer-0 match.(LPC2138) But problem is that when I debuge the code in Keil Complier it does not go to ISR. I aslo use the Sample code from keil that genrate interrupt on Timer match.But that aslo give same problem. Does it need to change Start up code before you write code for Interrupt.
Below I have given code that I hvae written.
#include<LPC21xx.H>
void T0isr(void) __irq;
unsigned int x;
int main(void) { IO0DIR=0XFFFFFFFF; T0TCR=0X00000000 //TIMER0 COUNTER DISABLE T0TC=0X00000000; //TIMER0 COUNTER SET TO 0 T0PR=0X00000001; //PRESCLAR FOR TIMER0 SET TO 1 T0PC=0X00000000; //PRESCLAR COUNTER FOR TIMER0 SET 0 T0MCR=0X00000003; //MR0 SET TO RESET AND GENERATE INT T0EMR=0X00000000; //MRO SET DO NOTHING ON MATCH T0MR0=0XFFFF; //MR0 SET 0XFFFF
VICVectAddr4 = (unsigned)T0isr; //Set the timer ISR vector address
VICVectCntl4 = 0x00000024; //Set channel
VICIntEnable = 0x00000010; //Enable the TIMER-0 interrupt
T0TCR=0X00000001; //TIMER0 COUNTER ENABLE
for(;;);
void T0isr (void) __irq { T0TCR=0X00000000; //TIMER0 COUNTER DISABLE IO0PIN=0XFFFFFFFF; //HIGH THE OUTPUT for(x=0;x<10000;x++); // DELAY IO0PIN=0X00000000; //LOW THE OUTPUT for(x=0;x<10000;x++); // DELAY T0IR= 0x00000001; //Clear match 0 interrupt VICVectAddr = 0x00000000; //Dummy write to signal end of interrupt
T0TCR=0X00000001; //TIMER0 COUNTER ENABLE }
Hello AMOGH PRABHULKAR,
it is not necessary to change the startup code. Be aware that interrupts are disabled during debugging with single steps. It is better to set a breakpoint inside the interrupt function and then perform a GO command.
Below is your modified code which works on a Keil MCB2130 board and also in uVision Simulation.
#include <LPC213x.H> // LPC213x definitions unsigned int x = 0; __irq void T0isr (void) { x ^= 1; if (x) IOSET1 = 1UL << 16; // switch LED on else IOCLR1 = 1UL << 16; // switch LED off T0IR = 0x00000001; // Clear match 0 interrupt VICVectAddr = 0x00000000; // Dummy write to signal end of interrupt } int main(void) { IODIR1 = 0x00FF0000; // P1.16..23 defined as Outputs (LEDs) IOCLR1 = 0x00FF0000; // Turn LEDs off T0TCR = 0x00000000; // TIMER0 COUNTER DISABLE T0PR = 0x00000080; // PRESCLAR FOR TIMER0 T0MCR = 0x00000003; // MR0 SET TO RESET AND GENERATE INT T0MR0 = 0xFFFF; // MR0 SET 0XFFFF VICVectAddr4 = (unsigned)T0isr; // Set the timer ISR vector address VICVectCntl4 = 0x00000024; // Set channel VICIntEnable = 0x00000010; // Enable the TIMER-0 interrupt T0TCR = 0x00000001; // TIMER0 COUNTER ENABLE for(;;); }
Best Regards, Martin Guenther
Dear Martin,
Thanks for reply.
I complied your code in keil(Evaluation version).Does "interrupt " simulate in Evaluation mode?
I used your program Hex code in "Proteus-7" for hardware(LPC2138) simulation to see interrupt but it don't work.
Does there is problem in Keil compiler or Proteus-7?
regads, Amogh
Yes, the simulator do support interrupts. If it didn't, it would be meaningless to use it.
