is it possible to create an array of mailboxes? I would like to use the mailbox objects as followes:
int i; for (i = 0; i < 5; i++) os_mbx_wait(mbx[i], &ptr, 0x000A);
Thanks for every hint!
Best regards, David
Thanks!
This code snippet is only an example. In fact i have 5 different mailboxes and in dependency of an integer index I have to read a specific mailbox like
But I don't know how to use
os_mbx_declare(...); os_mbx_init(...);
for declaring and initializing the mailbox array.
You know what I mean?
Best regards! David
You can do it, but what do you want to accomplish? The code, as written, will wait up to 10 ticks for five different mesasges, but you won't know which message arrived and which not...
By itself, pointer to message object can be either standalone or array element...
