fopen fails after numerous successes
I have trouble writing an file-copy function.
My fcopy-function should read data from a file into a buffer, then write the buffer to another file.
It works fine for several times in succession (see test_fcopy), but then the sourcefile suddenly can't be opend (fopen returns 0x00).
Heap size is 0x10000 (wich is very big, I guess).
Any ideas?
Marco
int test_fcopy()
int rc;
int i;
  for(i=0;i<100;i++)
    rc = fcopy("F:dest.txt", "F:source.txt");
    if(rc != FILESYSTEM_OK)
      //rc != FILESYSTEM_OK after 10 cycles,
      //depending on file size
      break;
int fcopy(char *destinationfile, char *sourcefile)
#define COPY_BYTES 512
char copy_data[COPY_BYTES];
FILE *dest;
FILE *source;
int c_read;
int c_write;
int rc;
  rc       = FILESYSTEM_OK;
  //open source file for reading
  source = fopen  (sourcefile, "r");
  //open destination file for writing
  dest   = fopen  (destinationfile, "w");
  if((source) && (dest))
  {//if both  files could be opend
    while (!feof (source))
      //read bytes from source file to ram
      c_read  = fread((void*)&copy_data,
                       1,
                       COPY_BYTES,
                       source);
      //write bytes from ram to destination file
      c_write = fwrite((void*)&copy_data,
                        1,
                        c_read,
                        dest);
      if(c_read != c_write)
        rc = FILESYSTEM_ERROR;
    //Close files
    fclose(source);
    fclose(dest);
  else
  return(rc);
