access Violation for sram at address 0x80000000
Dear all,
Do anyone has an idea regarding how i can access external sram.
i am using
LPC2468,Cpress 2MB External SRAM,Keil ARM (µvision3)compiler in my application.
when i am read/write data to onchip sram it works fine but when we try to access external Sram it shows access violation after debugging.
the routine is as follows
if anybody has an idea Pls. help me in this regards..
#define A0EXT_MEM 0x80000000
#define A0BLOCK_SIZE 512
Init_EMAC()
  //configuring EMC
  PINSEL9  = 0x10550055 ;//A[19:16]/P4[19:16 & 31:30 & 27:24]   enable CS0 ,BLS0,BLS1,WE,OE
  // select D0 -D15
 //select A0- A19
ReadFromSRAM
//Reading from the address 0x80000000(CS0) leads access violation no read permission
for(i = 0 ; i < A0BLOCK_SIZE ; i += sizeof(unsigned int)){
data = *(unsigned int*)((unsigned int)&A0EXT_MEM + i);
WriteToSram()
 //Writing to the address leads access violation no write perission
*(unsigned int*)((unsigned int)&A0EXT_MEM + i) = data;
Regards
Tripathi
