I'm using uVision3 V3.80 with an assembly project.
In the uVision editor, when I select a block of text, right-click and in the pop-up menu select "Advanced > Comment Selection", the editor comments the code with C comments:
// mov a, #1 // mov b, #2 etc.
Is there a way to get "Advanced > Comment Selection" and "Uncomment Selection" to work with assembly files, and insert the assembly comment character ";" instead of C "//"?
