I have several warnings when I compile my project with uVision2. I have L1, L2 and L16 warning. The thing is that I have some registers declared as EXTERN xdata volatile in .h files which are used in other .c files. And is seems that there are problems there.
I have seen that "*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL" may be caused by a missing library, http://www.keil.com/support/man/docs/bl51/bl51_l1.htm.
So I generated a library specifying the output option create library in the target options window. I included the library in the project and recompile. Now I have also L16 warnings... and the other warnings are still there.
thank you
Thank you,
I have checked again the files that were included in the project and added again the library and now it works fine. I haven't anymore there L1 warnings (just one L16)
thanks for your help
I have seen that "*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL" may be caused by a missing library The warning indicates that no module containing the variable is linked in, be that from a library or directly.
first verify that the variable, indeed exist in some other module.
For debugging purposes get rid of the library and check the list of included modules in the M51 file and then find out why the module where the variables is is not linked in.
I have found that when having a "linking mystery" the fastest way to resolve the mystery is to link EVERYTHING directly, with only the Keil libraries, then when everythintg links warning and error free you can move some modules to a library.
