Dear All,
I'm working on SPI communication on two LPC2138. I prepared a board based on MCB2130 and just want that first LPC2138 works as Master and second works as Slave. I want to make them communicate as bi-directional and via interrupt. Could you please give me an example works on Realview Compiler? I couldn't make work the example spi file in lpc21xx_insidersguide.zip I also couldn't make work which is listed in philips LPC2138 pages.
Opti
... and failed to get them working.
What makes you think that just taking another example will be any more successful?
Don't you think it would be more productive to try to find out why the 2 examples so far don't work?
eg, if there is a fault or basic design flaw in your hardware, then no example is going to work!
You need to learn how to Debug! See www.8052.com/.../120313 for some tips...
It is funny that you got too much angry about my question. Yes, i spent about 2 days on connecting mcu's via spi and i got failed. I see no weird thing about this. I'm just kindly asking for help. If you don't like to help, this is "your" time. Dont waste it for newbies. Is there any "friend" can help my about my problem except Andy please?
But, after 2 days, you should have at least some idea why the communication is not working.
eg:
Have you verified the hardware connections?
Is the Master generating the correct clock?
Is the Master generating the correct slave-select?
Is the Master generating the correct data on its output (MOSI) line.
Can you get your Master to talk to a "standard" SPI slave device; eg, an EEPROM or some other standard chip?
"I'm just kindly asking for help"
And you don't think it helpful to help you to debug what you have?
As I said, debugging is an essential skill - and is a great opportunity to start to acquire it!
Actually, thinking about it, 2 days is not very long to have thoroughly studied two samples consisting of both a slave and a master - and on 2 separate processors!
By the time you've studied the sample to see how it works, adapted it to your specific requirements, got it building & integrated with your own code - that could easily amount to a day's work before you even start any debugging!
So don't give up on those samples just yet - hang in there a bit longer!
Hellow,
I took your advice and started to debug example code. I realized that spi startup code is a little problem. Here is my code and schematic :
#include <LPC21xx.H> /* LPC21xx definitions */ #include <string.h> /* LPC21xx definitions */ #define SPI_OK 0 #define SPI_ERROR 1 #define SPI_BUSY 2 static unsigned char state; // State of SPI driver //static unsigned char msg[5]; // pointer to SPI data buffer static unsigned char msg[5]; // pointer to SPI data buffer static unsigned char count; // nr of bytes send/received long timeval; void wait (void) { /* wait function */ unsigned long i; i = timeval; while ((i + 10) != timeval); /* wait 100ms */ } /* Timer Counter 0 Interrupt executes each 10ms @ 60 MHz CPU Clock */ void tc0 (void) __irq { ++timeval; T0IR = 1; // Clear interrupt flag VICVectAddr = 0; // Acknowledge Interrupt } /* Setup the Timer Counter 0 Interrupt */ void init_timer (void) { T0MR0 = 149999; // 10mSec = 150.000-1 counts T0MCR = 3; // Interrupt and Reset on MR0 T0TCR = 1; // Timer0 Enable VICVectAddr0 = (unsigned long)tc0; // set interrupt vector in 0 VICVectCntl0 = 0x20 | 4; // use it for Timer 0 Interrupt VICIntEnable = 0x00000010; // Enable Timer0 Interrupt } void vSPI0_ISR(void) __irq { if ((S0SPSR & 0xF8) == 0x80) { ++count; if (count < 40) S0SPDR = msg[count-1]; // sent next byte else state = SPI_OK; // transfer completed } else // SPI error { *msg = S0SPDR; // dummy read to clear flags state = SPI_ERROR; } S0SPINT = 0x01; // reset interrupt flag VICVectAddr = 0; // reset VIC } static void SPI_Init(void) { VICVectAddr2 = ( unsigned long ) vSPI0_ISR; VICVectCntl2 = 0x02A; VICIntEnable |= 0x0400; PINSEL0=0x5500; // Configure Pin Connect Block VPBDIV=0x01; // Set pclk to same as cclk S0SPCCR=0x08; // Set to highest speed for SPI at 60 MHz -> 7.5 MHz VICIntSelect &= ~( 0x0400 ); S0SPINT=0x01; // Device selected as master S0SPCR=0xA0; } int main (void) { unsigned int j; /* LED var */ unsigned long volatile start; // volatile avoids loop optimization /* for (start = 0; start < 10000000; start++) { ; // wait for debugger connection (about 0.3 sec) } */ SPI_Init(); IODIR1 = 0xFF0000; /* P1.16..23 defined as Outputs */ init_timer(); S0SPDR=0x42; strcpy(msg, "OPTIZ"); count = 0; while (1) { for (j = 0x010000; j < 0x800000; j <<= 1) { /* Blink LED 0,1,2,3,4,5,6 */ IOSET1 = j; /* Turn on LED */ wait (); /* call wait function */ IOCLR1 = j; /* Turn off LED */ } for (j = 0x800000; j > 0x010000; j >>=1 ) { /* Blink LED 7,6,5,4,3,2,1 */ IOSET1 = j; /* Turn on LED */ wait (); /* call wait function */ IOCLR1 = j; /* Turn off LED */ } } }
img155.imageshack.us/.../spi.jpg img195.imageshack.us/.../osc.jpg
I couldnt fix "count" variable. If i decrease count value, it stops.. What do you say about this?
Optizyme
The layout of your code seems to have lost something in posting. Note that you need to use spaces not TABs for indentation - the interpretation of TAB characters is (almost) entirely unpredictable!
Your image links don't seem to work.
Please describe in more detail what seems to be the problem with the 'count' variable?
