I'm seeing some strange behavior when initializing arrays. I'm using the following code to intialize a 256 element array to zeros:
xdata char myarray[256] = {0}
The code seems to hang when I run this using my debugging hardware. If I run this with the simulator it seems to work fine. If I reduce the number of elements to 50 it works OK, but increase it to 60 and I get it to hang again. Has anyone seen this before? Is it a hardware issue vs compiler/assembler issue?
Thanks for the prompt responses. I went back and reviewed my code and noticed the watchdog timer was enabled. The watchdog is enabled by default on a reset and was timing out before the initialization could complete. This explains why seemed to hang and is why it works fine with a 50 element array, but not with 60 elements. I took Per's advice and removed the explicit zero initializations and now allow the compiler to do it for me.
Along the same lines...I noticed a substantial decrease in the code size when I move nonzero global variable initialization into the main body of code instead of when I define the global variables. I saw a reduction of close to 130 bytes for a single variable if I go about things this way. Is there really that much "black magic" going on in the startup code? This is very surprising as it only takes 3 bytes to assign the same nonzero value in the main body.
When you have initialized global and static variables, then the linker will take all the initialized data and compress and store in a block in the flash. Ãou will then get a decompress function from the runtime library that will decompress this data from flash and assign to your variables.
A non-global or non-static variable that has an assign is not considered initialied data, i.e. the compiler will generate code that assigns the value when the execution reaches that point in the code.
The next thing to think about: Make sure that you separate initialized data that will be modified by your program, and initialized data that will never change. If the data need never change, then you should modify the source code so you don't get a RAM copy of the variables. Your program can access the values directly from the code memory (normally flash) instead.
