I'm seeing some strange behavior when initializing arrays. I'm using the following code to intialize a 256 element array to zeros:
xdata char myarray[256] = {0}
The code seems to hang when I run this using my debugging hardware. If I run this with the simulator it seems to work fine. If I reduce the number of elements to 50 it works OK, but increase it to 60 and I get it to hang again. Has anyone seen this before? Is it a hardware issue vs compiler/assembler issue?
Thanks for the prompt responses. I went back and reviewed my code and noticed the watchdog timer was enabled. The watchdog is enabled by default on a reset and was timing out before the initialization could complete. This explains why seemed to hang and is why it works fine with a 50 element array, but not with 60 elements. I took Per's advice and removed the explicit zero initializations and now allow the compiler to do it for me.
Along the same lines...I noticed a substantial decrease in the code size when I move nonzero global variable initialization into the main body of code instead of when I define the global variables. I saw a reduction of close to 130 bytes for a single variable if I go about things this way. Is there really that much "black magic" going on in the startup code? This is very surprising as it only takes 3 bytes to assign the same nonzero value in the main body.
The watchdog is enabled by default on a reset and was timing out before the initialization had you mentioned your derivative (I guess a SILabs deviate (f3x-up)) cheking the watchdog would have been the first advice you got
nice to c some revent information on following web pages. microcontroller51.blogspot.com/ and see also http://picinf.blogspot.com/
.. would shut down.
It seems that waay too many figure that they can start a forum as a means of making themselves feel important, and do not give a friggin hoot that the information get spread so thin that it becomes virtually impossible to find.
"nice to c some revent information ..."
Nope. No "revent" (sic) information there.
The good doctor, in addition to being a SPAMMER, is a dunce.
s/c/see/ s/revent/relevant/
is "doctor spam" in any way related to professor zuisti (my self proclaimed dear friend...)
Yes, it would be nice to see some relevant information - for once - in the links posted by Dr Spam...
is the name chosed because someone has to be Gullible to believe any of the crap.
My deer freinds,
I do'nt know who doctor spam is!
Always your freind.
Zeusti.
(now approved by Geofrey Dunn)
(now approved by Geofrey Dunn) as that the same as when you claimed approval by me because I posted that one of a hundered of your posts were correct?
