could you tell me if the following controller are supported by keil uvision: i.MX31, i.MX356, PXA270 (all from freescale).
Are there any sample-programm-files for these controllers available?
best regards JJ
http://www.keil.com/dd
but is it possible to work with such an controller, when I will write the startup-file?
Or are there any other things (without the use of the simulator)
JJ
Mentioned processors are not supported by MDK (i.MX31 and i.MX356 have ARM11 cores).
do you know a tool which supports ARM11 processors?
gcc?
ARM RVDS. Essentially the same compiler as used in MDK. IAR EWARM. GCC, as previously mentioned
Regards Marcus http://www.doulos.com/arm
