I am having a very strange behavior on my project. I am calling a class method that access a certain atribute. I have debugged the application and on the second method call I have noticed that the attribute address changes. The class this pointer have changed and the atribute update was not accomplished successfully.
Does anyone have noticed this bug?
Regards, André Moutinho
No, we don't have your project, so we obviously can't notice this bug.
If you do post the source, we might be able to spot the bug in your code - unless you just have too little stack space or are using dynamic memory allocations and have failed to set up a large enough heap.
Thanks for your response.
Unfortunatelly I cannot post the source code. It is very big and has around 200 modules (cpp files). I will try increasinng the stack space. I have noticed this problem by creating a static class firstly. I then have changed to dynamic allocation and the problem did happened again.
Thanks André Moutinho
