I'm using the following system: Keil: Realview MDK-ARM ver4.10 Jtag debugger: Coocox colink processor: generic cortex-m3 with the following memory layout :
0x00000000-0x00004000 -ROM (read only) 0x20000000-0x20008000 -RAM
In Keil uVision, I define the TARGET option memory areas with the corresponding values: IROM:0x00000000 size:0x4000 (startup checked) IRAM:0x20000000 size:0x8000
In the Linker option, I select the "Use memory layout from Target Dialog".
When i start the debug sessions, software breakpoints are used for the ROM area. What is wrong?
"some debuggers (i.e. J-Link) can do this, they reprogramm the flash."
Yes, but if I'm correctly informed, that only happens when the developer tries to add more breakpoints than is supported in hardware.
BR, /th.
How is it possible to use software breakpoints in ROM? As i said, ROM is read only and hence the debugger cannot write to it. The debugger cannot replace the instruction with a BREAKPT instruction.
Have you also asked them about this?
Why do you think that this is wrong?
