I want to write a function (ARM) that will run in a different initial RAM addresses. Part of the program in ASM, and part of C. The problem is that variables declared in the ASM, as seen in C are still in the same address.
EXP:
in asm file:
test_val dcd 0x5555555 export test_val BLX main_c_code
in C file:
extern int test_val; void main_c_code(void){ ... test_val = 0xAAAAAAAA; ... }
after build everything works, when it loads the applications to address eg 0x1000 (default) test_val is at addr. eg. 0x1004 but when you want to load applications to address eg 0x2000, Part C test_val still fits the data to addr 0x1004 instead of 0x2004. how to force the compiler to the use of
ADR R0, test_val
instead of
LDR R0, = 0x4
