Hello everybody, Please, is there anybody that used the library TCPIP by modem ?
I should developing a FTP server reachable by internet connection. I use a modem (telit GM862) that have already tcp/ip stack inside, but don't have a FTP and besides, I think that to use the micro library is more flexible and so I want use it. Normaly, I able to connect to modem with internet by GPRS and it obtain the IP address from provider, but if I want to use only GPRS connection of the modem and don't the stack tcp/ip is it possible ? Maybe I must use the PPP protocol ? I saw the Http_demo example for NXP micro that doesn't have the ethernet controller and it uses the PPP protocol, but the connection is done by rs232... How do I set the library for this use ? How do I inject the data received from modem so them it can to be elaborate from the library?
Thank in advance to everybody.
Regards Nicola
"...that have already tcp/ip stack inside, but don't have a FTP" - Yes it does. See Telits documentation.
For ref, a completed project with code exists here:
www.siwawi.arubi.uni-kl.de/.../m2m.html
Google is your friend<i/>
Ok, Thanks for your reply.
Unfortunately, there aren't available the sources code...
Regards, Nicola
