main() runs again after completion of code
I wrote a simple c program in keil to set the voltage on/off for two motors for 10 sec. But when i debug the program, it runs correctly till the end and at the last step of the code it returns to 1st line of main()again, performing all steps again.So the program seems to run for infinite time. Can you suggest me a solution. The same code when i copied and pasted it to another file and ran it on different pc it runs well!!>>?
  • You do not specify the toolset that you are using. If it is the PK51, then Keil always puts a default LJMP to Main at the end of your code. This is intentional. You must have a continuous loop of some type in your C51 code. It is up to the programmer to place a forever loop at the correct place in the code.
    Read your "Getting Started Manual" for the forever loop requirements.
    The C51 is not a PC. The code has NO place to return after code completion.
    Bradford
    Bradford
