RF transmitter and uC interface
hi every one
although i have went through another topic with the same thing but i wanted to ask the question of whether the resulting module be small enough to be contained in a hand held device
as i am trying to make a portable device which a person can carry around .
Also any suggestions on the type of uC to be used will be appreciated.
right now i am thinking of using LPC900 .
but i think that will be very small.
what i require is a low power consuming uC with 2-3 interrupts and yes transmission and reception capabilities.
  • i wanted to ask the question of whether the resulting module be small enough to be contained in a hand held device
    but can anybody on this earth answer that, except you? you sort of asked the most generic possible question before you started even to plan WHAT you are going to do (so it seems). you can answer all those questions only after a complete set of requirements is written!
