Hi, I use AT89S52 in a project. I send and receive data through TXD, RXD pins to a GSM module for sending SMS to another mobile equipment. I use watchdog facility and the watchdog counter is reset at every 256 counts. My crystal frequency is 11.0592 MHz. It happens once in a while that the uC doesn't respond and remains as if it hangs. Then it has to be RESET again. I doubt whether it happens while serial data reception and sending happens simultaneously. I wrote the program in C using KEIL IDE. My questions are 1) What are the special precautions to be taken in this case?(sending and receiving simultaneously) 2)why this happens even when the watchdog is active? It will be highly appreciated if anybody can give some guidance.
assuming your watchdog is working and configured to reset the MCU, it is safe to assume that your program ends up in a condition in which it services the watchdog but not performing its main function.
I thought of that possibility. But still unable to find out any reason.
Which possibility?
And why you really, really shouldn't be using one in an application like this:
www.8052.com/.../119931
THANK YOU VERY MUCH. Really useful information.
Suppose there is a spike coming to the reset pin and it doesn't have sufficient duration to RESET properly. I think that can also lead to a 'hang' situation like this. Am I right? If that is the case, a good power supply(without glitches) can also solve my problem. Right? Is there any IC with built in RESET and pin compatible with 89S52 ?
If that is the case, a good power supply(without glitches) can also solve my problem. Right? No, there is no such thing as a "power supply(without glitches)" no power supply can handle e.g. a "ground jump". Is there any IC with built in RESET and pin compatible with 89S52 ? I guess with RESET you mean supervisor and I recall no uC with a built in supervisor that is "pin compatible" but e.g. all SILabs chips have built in supervisor
keep hawing if you like but you will end up with a supervisor.
Check out the AT89C51XXX family for pin compatibility and built in reset supervisors.
There are actually stupid internal watchdogs that are using the same clock source as the processor core. That means that if the processor clock stops, then the watchdog stops.
With an external watchdog, you know that it has independent timing. Even better is of couse an external watchdog that can't just reset the processor, but that can even power-cycle the processor.
Can you please elaborate this point a little more?
1) Some _bad_ processors are using the processor clock to drive a watchdog just as if it was a normal timer. Obviously, that means that if you stop the clock (often possible with processors that have power-save support), then the watchdog will also stop seeing time. If the watchdog doesn't see time, then it will obviously no longer perform any watching.
2) Sometimes, a processor can lock up in a way that the reset signal will not restart the processor fully. To one part, this may be caused by bad internal design - some state machines not being correctly reset by the reset signal. To some parts, you can get an electric latch-up, in which case the semiconductors in the chip behaves as a tyristor - shorting until you remove the current. Such a latchup will then require that you can remove the power from the processor. Sometimes, it's enough to remove the power a very short time. Sometimes, capacitors gets charged enough that it may take minutes or hours for them to discharge enough that the latchup problem ends. Obviously, a good design should protect all processor signals from overvoltages, but that doesn't mean that it can't happen.
An external watchdog always have its own time base - normally based on an external or internal RC circuit. That means that you will know that you fulfill the requirements of some standards - that the supervision circuit has independent timing.
An external watchdog is powered separately, which means that it can be used to turn off the power to the processor and thereby force a cold-start reset.
But another thing already covered in this thread: A watchdog should not be kicked by automatic logic. Too many designs are using timer interrupts or similar to kick the watchdog. That means that the program may be stuck in an infinite loop somewhere, while the interrupt is still ticking constantly and keeping the watchdog serviced.
The goal with a watchdog is to minimize the probability that the watchdog gets serviced if the system is in any state where it isn't fully in control.
You want to have a lot of validation tests before you perform a kick - something like:
if (uart_working && communication_task_working && rtc_ticking && uptime_ticking && last_i2c_comm_age < I2C_FAIL_TIMEOUT && last_spi_comm_age < SPI_FAIL_TIMEOUT . . . && data_integrity_ok) { // I'm reasonably confident everything is ok. // Now kick watchdog kick_register = MAGIC_KICK_PATTERN; }
So on one hand, you should only kick the watchdog when you are very sure that everything is ok.
On the other hand - the watchdog is not a random safety line that should be too much relied upon. If you get a watchdog reset, then it's time to figure out why - that is an indication that you have a hardware or software error that should be solved. I'm not fond of equipment that performs random resets once/day or week for some magic reason. "But it works" is the wrong answer. It obviously is not working if the watchdog gets used.
This isn't a threaded forum, so how about writing all new comments at the bottom of the thread? Or is it then too easy to figure out what new messages to read?
Thank you very much for the nice explanation. As mentioned earlier I faced a problem of program stops (may be due to voltage spikes). I added some filtering and made some changes in component values in RESET circuit . This gave good results. Still I wanted to take extra precaution. It is not that I am using external watchdog instead of trying to improve my design An external watchdog is powered separately, Is it the case always? I use the same power source for both and the external supervisor circuit is expected to RESET my processor if it stops.Is it OK?
Component values in reset circuit? Are you not using a tripod - a special reset chip just taking VCC, GND as inputs and having reset as only output? RC resets are seldom good.
Powered separately as in having a separate lead for power. An internal watchdog is powered from the same VCC leads as the processor core, which means that the watchdog can't just cut the power to the processor. With an external watchdog, it's possible to have the watchdog cut the power for a second to the processor by letting the watchdog drive a FET.
I tried supervisor IC DS1232. Working well.It has got a watchdog also which is monitoring the ALE pin of my uC toggling an external watchdog with ALE is no good, ALE can, and most likely will keep running with runaway code.
Anyhow the '1232 is a supervisor AND watchdog, so why do you still talk about the RC reset.
I, personally, am of the opinion that an internal watchdog (ONLY the kinds that require two consequent writes to be fed) is a better choice, but here is a case where opinions differ. Anyhow there is no discussion about two points a) any WD is better than none b) if the WD fires you have a problem that you should fix
Why do I consider an internal watchdog a better choice? I think the likelyhood of a port pin toggling in runaway code is greater than two specific consequent writes
Earlier I was using RC circuit. Now started using DS1232
