I have designed my own prototype board using CC1010 core.
I have a dongle which works for me when I use it with Atmega16 chip with ponyprog software. The dongle only ghanges LPT1 parallel port to the ISP port using MISO, MOSI, SCK signals. RESET signal comes from the button and chip select (PROG) is held down when I try download the flash. When I try to use the dongle with CC1010 Flash Programming tool, it success never. It says can't connect a device.
Regards Timo
It's not a Keil tool. (it's home made tool for Atmel chip) Can I use Keil Ulink2 debugger to download .hex into CC1010 flash. If it is possible, how it is done? I read from the Keil website that the Ulink2 is only ARM tool. Does it fit CC1010 core and 8051 processor?
Regards
Timo
Is that a Keil tool?
If not, better ask whoever's tool it is!
