Hi, I encountered problems using the USB-CDC-example out of the Atmel software package 1.5 with an AT91SAM9260. Sometimes, when sending data using USBD_Write, the USB driver hangs in the function/define SET_CSR waiting for the AT91C_UDP_TXPKTRDY flag. Other times, USBD_Write returns USBD_STATUS_LOCKED all times, while receiving data works fine.
char USBD_Write(unsigned char eptnum, const void *data, unsigned int size, TransferCallback callback, void *argument) { Endpoint *endpoint = &(endpoints[eptnum]); Transfer *transfer = &(endpoint->transfer); // Check that the endpoint is in Idle state if (endpoint->state != UDP_ENDPOINT_IDLE) { return USBD_STATUS_LOCKED; } trace_LOG(trace_INFO, "Write%d(%u) ", eptnum, size); // Setup the transfer descriptor transfer->data = (char *) data; transfer->remaining = size; transfer->buffered = 0; transfer->transferred = 0; transfer->callback = callback; transfer->argument = argument; // Send the first packet endpoint->state = UDP_ENDPOINT_SENDING; while((AT91C_BASE_UDP->UDP_CSR[eptnum]&AT91C_UDP_TXPKTRDY)==AT91C_UDP_TXPKTRDY); UDP_WritePayload(eptnum); SET_CSR(eptnum, AT91C_UDP_TXPKTRDY); // If double buffering is enabled and there is data remaining, // prepare another packet if ((BOARD_USB_ENDPOINTS_BANKS(eptnum) > 1) && (transfer->remaining > 0)) { UDP_WritePayload(eptnum); } // Enable interrupt on endpoint AT91C_BASE_UDP->UDP_IER = 1 << eptnum; return USBD_STATUS_SUCCESS; }
Does someone else have similar problems?
And another question concerning the USB-CDC-driver: Under WinXP usbser.sys is used as driver for the device and it can be used as a serial port. When connecting to the port (e.g. by HTerm) and then resetting the board, the connection can not be established again, until the device is plugged out and in again. Is this a problem of the USB-CDC-driver on the device or a generic problem of the windows driver?
