hi all, I'm Giacomo and I'm an italian engineering student, I'm workin on STM32f103B with Keil uvision 3.72 and ulink2 debugger.
I'm trying to read adc signal (POS1) on PA1 and plot it on logic analyzer, so I configured the trace following the "ULINK@2 User's Guide" at http://www.keil.com/support/man/docs/ulink2/ when I write in command window (under debug mode): POS1 I succesfully read the variable value, but when I try to plot this variable in logic analyzer, (LA POS1) I obtain always 0x00000000
while run the program, after some second I get the message on trace status bar: "trace no syncronization".
maybe I have a clock problem, what is the correct ccore clock?
thanks for help
i included STM32DBG.ini but the problem remained the same. I don't know what parameter I have to select in configuration of STM32DBG.ini at Trace_mode (asyncronous,etc...) setting the core clock at 72Mhz, running in debug mode, immediately display "trace no syncronization", while if I set 1Mhz, the text "trace no syncronization" is displayed after long time.
For the STM32 you need to include the STM32DBG.ini or you will get an error similar to the one you are receiving.
Check out App Note 197 as it is specifically for setting up serial wire debug on the STM32.
http://www.keil.com/appnotes/list/arm.htm
