compiler stuck and CPU has high load
When putting the following code into any .c file building the project makes the compiler stop and the process load for the C166.exe process is very high.
void buffer[64]= {"test the flash"};
I am pretty sure that this is a syntax error. However it took me some time to find the errornous line as the compiler was stuck and did not come up with anything.
I am not sure if this is a compiler bug. Could anyone test it?
IDE-Version:
µVision V4.00a
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
Tool Version Numbers:
Toolchain:        PK166 Prof. Developers Kit  Version: 7.00
Toolchain Path:    D:\Keil_c166v7_demo\C166\BIN\
EC++ Compiler:      EC166.Exe       V1.09d
C Compiler:         C166.Exe       V7.00
Assembler:          A166.Exe       V5.33
Linker/Locator:     L166.Exe       V5.25
Librarian:             LIB166.Exe       V4.26
Hex Converter:      OH166.Exe       V4.7a
CPU DLL:               S166.DLL       V3.74
Dialog DLL:         D167.DLL       V2.52
Target DLL:             BIN\UL2OCDS.DLL       V1.23
Dialog DLL:         T167.DLL       V2.49
