Hi all,
If the processor tries to go back from the test() function to the main() function, the program counter gets always the wrong address - so that an undef handler occurs.... (processor is searching for an programm code in the sdram...). The whole programm is stored in an external nor flash device (0x10000000).
void test(void) { //do some stuff... return; } void main(void) { test(); }
The user stack size is 0x800. That's a short part of the disassembly where the jump to the sdram occurs (the next step after 0x100012D4). According to the map file, the function test() is using the memory space until 0x1000012D8 and the next function starts at 0x100001304. I'm not sure about the space within these two points? All these values are also stored in the nor flash device...
522: return; 0x100012C8 E7980185 LDR R0,[R8,R5,LSL #3] 0x100012CC E3C00001 BIC R0,R0,#0x00000001 0x100012D0 E7880185 STR R0,[R8,R5,LSL #3] 523: } 0x100012D4 E8BD8FF8 LDMIA R13!,{R3-R11,PC} 0x100012D8 544F5250 DD 0x544F5250 0x100012DC 0050495F DD 0x0050495F 0x100012E0 0A50490A DD 0x0A50490A 0x100012E4 00000000 DD 0x00000000 0x100012E8 606E6F64 DD 0x606E6F64 0x100012EC 6E6B2074 DD 0x6E6B2074 0x100012F0 7420776F DD 0x7420776F 0x100012F4 20736968 DD 0x20736968 0x100012F8 6B636170 DD 0x6B636170 0x100012FC 000A7465 DD 0x000A7465 0x10001300 68746520 DD 0x68746520 0x10001304 00000020 DD 0x00000020 39: pbuf->hdr->flag = used;
best regards Howard
I'm not sure if this is a question. You probably want to know what could cause this. It could well be that the part where it says '//do some stuff' corrupts the stack. I would start debugging this by stopping the program at the return statement and inspecting the stack. Then I would try to find the exact point at which the stack gets corrupted. The good news is that it happens always: the bug is easily reproduced, so hopefully it is also easily fixed.
If you write the contents of this space in ASCII, you'll see: _IP IP don't know this packet eth Apparently, these are literal constants used in your program.
Hi Mike, thank you very much for your answer!
Yes, these are the terms of the printf() functions using in this c-function test(). Very interesting, that this part is here located. Do you know if the printf() function use the stack or the heap section?
I'm not sure if this is a question. You probably want to know what could cause this. I would start debugging this by stopping the program at the return statement and inspecting the stack.
Ok, that makes sense. But how could I inspect the stack with Keil? I just took a look at the sram position, where the stack is located. It seems that the area isn't correct initialized because the above area of the stack is filled with 0x00 and the lower part is full with code (variables).
scatter-loading file:
ARM_LIB_HEAP 0x312000 EMPTY 0x1000 { } ARM_LIB_STACK 0x314000 EMPTY -0x1000 { }
map-file:
Image$$Relocate_region$$ZI$$Limit 0x003036e8 Number 0 anon$$obj.o(linker$$defined$$symbols) Image$$ARM_LIB_HEAP$$Base 0x00312000 Number 0 anon$$obj.o(linker$$defined$$symbols) Image$$ARM_LIB_HEAP$$ZI$$Limit 0x00313000 Number 0 anon$$obj.o(linker$$defined$$symbols) Image$$ARM_LIB_STACK$$Base 0x00313000 Number 0 anon$$obj.o(linker$$defined$$symbols) Image$$ARM_LIB_STACK$$ZI$$Limit 0x00314000 Number 0 anon$$obj.o(linker$$defined$$symbols)
Moreover do you know if it is possible to see if the size of the different stacks (irq, user, supervisor stack...) are big enough?
I don't know. I suspect that printf() doesn't use heap, because there are applications where you'd use printf() and would want to avoid using heap, and the standard library should support that.
I think that's what the Call Stack Unwinder is for. You could also analyze the disassembly and derive expected stack usage from that.
It seems that the area isn't correct initialized...
This seems normal. You would expect the used part of the stack to contain non-zeros, and the yet untuched part to be all-zeros.
One way is to let the program run for a while (stress-test it,) then stop it and inspect stack space. The untouched part of the stack is all-zeros. This should give you an idea of how much stack was used.
Could you show me a small example? The Call Stack Unwinder only displays the c-functions with their variables (and their values... there's no error) - but I can't find the relation between the Stack Unwinder window and the memory window displaying the top of the stack.
The test() function will be called if a new packet was received by ethernet. If this happens, the error occurs.... If I reduce the code within the test() function everything seems to work. Therefore I think there would be something wrong with the stack - but the stack size seems to be big enough. I'm not sure what a common size of the stack would be... maybe the printf() function is using a huge amount of the stack...
That's probably it. I would expect printf() to easily consume 1K bytes of stack (I don't have data to back this up, though.) As for required stack size for a typical program, it really strongly depends on the program. Deeply nested function calls and lots of large automatic variables can consume tons of stack space.
That's a lot.... Do you know a better way to transmit messages to the debug (rs232) interface containing the values of variables?
I also have installed two large buffers with 256 Bytes - one for a small receive ethernet frame and the other one to transmit the next ethernet frame....
Provided that, these huge buffers and the printf() function will overflow the stack - which possibilities do I have to avoid this? If I call another function, I always deliver only an pointer to the buffer - not the buffer. My stack size is 0x1000 = 4kByte - which is also a lot....
ok, now I was able to do some tests. The printf() function uses a lot of the stack size but that's not the problem.
I open the Call Stack Window, where the main() function is shown at the beginning. When the processor calls the testfunction() function and after that another function (testfunction2) where a memcmp instruction is executed - all previous values will be overwriten (e.g. in the main function)....
Call Stack Window: testfunction2() testfunction() main()
So the stack size is huge enough, but the programm is only using 0x200 of the whole stack (start at 0x314000). If the programm needs more space for the stack, the programm will start at the beginning of the stack 0x314000 and overwrite all values (located for example in the first function main()).
That means, when the programm tries to go back from the testfunction() to the main() function - the correct address for this jump is no longer located in the stack.
I hope you could give me some advice to solve this problem.
...another function (testfunction2) where a memcmp instruction is executed - all previous values will be overwriten
I'm not sure why you are mentioning memcmp - this function compares two memory regions, it shouldn't alter their contents. But it sounds like you almost found the exact place in the program where stack corruption takes place. Try locating the exact line of the source code which does it.
It is only a example - nearly every command which uses some space (stack) will occur that other variables will be overwriten.
I think there is something wrong that the processor doesn't add the new stack variables at the end of the actual stack location. For example I've a simple unsigned int i variable in the main() function, which is 0x00, but when the processor do some stuff in the testfunction2() the value is 0x20000041....
It is also a little bit strange, that I couldn't see any value in the memory window (start of the stack location) which is similar to the values shown in the stack window. I only see that the area from 0x314000 to 0x313F00 will change its values)
It could be stack pointer corruption then. If at some point in the program the stack pointer register is not updated properly (or updated improperly) then all subsequent stack operations would reference wrong memory locations. I don't think it's possible to corrupt the stack pointer by means of the C language only. It would involve pieces written in assembly, or improper handling of CPU mode switching, improper handling of interrupts etc...
I'm using the startup file from Atmel instead of the one from Keil, because it was easier to add some instructions to boot from an external flash device.
;------------------------------------------------------------------------------ ; After a reset, execution starts here, the mode is ARM, supervisor ; with interrupts disabled. ; Initializes the chip and branches to the main() function. ;------------------------------------------------------------------------------ AREA cstartup, CODE ENTRY ; Entry point for the application ; Reset Handler EXPORT resetHandler IMPORT |Image$$Fixed_region$$Limit| IMPORT |Image$$Relocate_region$$Base| IMPORT |Image$$Relocate_region$$ZI$$Base| IMPORT |Image$$Relocate_region$$ZI$$Limit| IMPORT |Image$$ARM_LIB_STACK$$Base| IMPORT |Image$$ARM_LIB_STACK$$ZI$$Limit| ; Perform low-level initialization of the chip using LowLevelInit() IMPORT LowLevelInit resetHandler ; Set pc to actual code location (i.e. not in remap zone) LDR pc, =label label ; Set up temporary stack (Top of the SRAM) LDR r0, = |Image$$ARM_LIB_STACK$$ZI$$Limit| MOV sp, r0 ; Call Low level init LDR r0, =LowLevelInit MOV lr, pc BX r0 ;Initialize the Relocate_region segment LDR r0, = |Image$$Fixed_region$$Limit| LDR r1, = |Image$$Relocate_region$$Base| LDR r3, = |Image$$Relocate_region$$ZI$$Base| CMP r0, r1 BEQ %1 ; Copy init data 0 CMP r1, r3 LDRCC r2, [r0], #4 STRCC r2, [r1], #4 BCC %0 1 LDR r1, =|Image$$Relocate_region$$ZI$$Limit| MOV r2, #0 2 CMP r3, r1 STRCC r2, [r3], #4 BCC %2 ; Cache Setup ------------------------------------------------------------------ ; Constants ICACHE_ENABLE EQU (1<<12) ; Instruction Cache Enable Bit MRC p15, 0, R0, c1, c0, 0 ; Enable Instruction Cache ORR R0, R0, #ICACHE_ENABLE MCR p15, 0, R0, c1, c0, 0 ; Setup Stack for each mode LDR R0, = |Image$$ARM_LIB_STACK$$ZI$$Limit| ; Enter Undefined Instruction Mode and set its Stack Pointer MSR CPSR_c, #ARM_MODE_UND:OR:I_BIT:OR:F_BIT MOV SP, R0 SUB R0, R0, #UND_Stack_Size ; Enter Abort Mode and set its Stack Pointer MSR CPSR_c, #ARM_MODE_ABT:OR:I_BIT:OR:F_BIT MOV SP, R0 SUB R0, R0, #ABT_Stack_Size ; Enter FIQ Mode and set its Stack Pointer MSR CPSR_c, #ARM_MODE_FIQ:OR:I_BIT:OR:F_BIT MOV SP, R0 SUB R0, R0, #FIQ_Stack_Size ; Enter IRQ Mode and set its Stack Pointer MSR CPSR_c, #ARM_MODE_IRQ:OR:I_BIT:OR:F_BIT MOV SP, R0 ; SUB R4, SP, #IRQ_Stack_Size SUB R0, SP, #IRQ_Stack_Size ; Supervisor mode (interrupts enabled) MSR CPSR_c, #ARM_MODE_SVC:OR:I_BIT:OR:F_BIT ; MOV SP, R4 MOV SP, R0 ; SUB R4, SP, #SVC_Stack_Size SUB R0, SP, #SVC_Stack_Size ; Enter User Mode and set its Stack Pointer MSR CPSR_c, #ARM_MODE_USR MOV SP, R0 SUB SL, SP, #USR_Stack_Size ; Enter the C code IMPORT __main LDR R0, =__main BX R0 END
I've added four of the instruction modes (undefined, abort mode and FIQ mode as well as the user mode).
Which parts of the startup file will affect the stack pointer?
here is the first part of the startup file:
; Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs ARM_MODE_USR EQU 0x10 ARM_MODE_FIQ EQU 0x11 ARM_MODE_IRQ EQU 0x12 ARM_MODE_SVC EQU 0x13 ARM_MODE_ABT EQU 0x17 ARM_MODE_UND EQU 0x1B ARM_MODE_SYS EQU 0x1F I_BIT EQU 0x80 ; when I bit is set, IRQ is disabled F_BIT EQU 0x40 ; when F bit is set, FIQ is disabled AT91C_BASE_AIC EQU 0xFFFFF000 AIC_IVR EQU 0x100 AIC_EOICR EQU 0x130 UND_Stack_Size EQU 0x00000000 SVC_Stack_Size EQU 0x00000008 ABT_Stack_Size EQU 0x00000000 FIQ_Stack_Size EQU 0x00000000 IRQ_Stack_Size EQU 0x00000100 USR_Stack_Size EQU 0x00000800 PRESERVE8 ; Area Definition and Entry Point ; Startup Code must be linked first at Address at which it expects to run. AREA VECTOR, CODE ARM ; Exception Vectors Vectors LDR pc,=resetHandler LDR PC,Undef_Addr LDR PC,SWI_Addr LDR PC,PAbt_Addr LDR PC,DAbt_Addr LDR PC,[PC,#-0xF20] ; Vector From AIC_IVR LDR PC,[PC,#-0xF20] ; Vector From AIC_FVR Reset_Addr DCD resetHandler Undef_Addr DCD undefVector SWI_Addr DCD swiVector PAbt_Addr DCD prefetchAbortVector DAbt_Addr DCD dataAbortVector DCD 0 ; Reserved Address IRQ_Addr DCD irqVector FIQ_Addr DCD fiqVector undefVector b undefVector ; Undefined instruction swiVector b swiVector ; Software interrupt prefetchAbortVector b prefetchAbortVector ; Prefetch abort dataAbortVector b dataAbortVector ; Data abort reservedVector b reservedVector ; Reserved for future use irqVector b irqHandler ; Interrupt fiqVector ; Fast interrupt ;------------------------------------------------------------------------------ ; Handles a fast interrupt request by branching to the address defined in the ; AIC. ;------------------------------------------------------------------------------ fiqHandler b fiqHandler ;------------------------------------------------------------------------------ ; Handles incoming interrupt requests by branching to the corresponding ; handler, as defined in the AIC. Supports interrupt nesting. ;------------------------------------------------------------------------------ irqHandler ; Save interrupt context on the stack to allow nesting */ SUB lr, lr, #4 STMFD sp!, {lr} MRS lr, SPSR STMFD sp!, {r0,r1,lr} ; Write in the IVR to support Protect Mode */ LDR lr, =AT91C_BASE_AIC LDR r0, [r14, #AIC_IVR] STR lr, [r14, #AIC_IVR] ; Branch to interrupt handler in Supervisor mode */ MSR CPSR_c, #ARM_MODE_SVC STMFD sp!, {r1-r4, r12, lr} MOV lr, pc BX r0 LDMIA sp!, {r1-r4, r12, lr} MSR CPSR_c, #ARM_MODE_IRQ | I_BIT ; Acknowledge interrupt */ LDR lr, =AT91C_BASE_AIC STR lr, [r14, #AIC_EOICR] ; Restore interrupt context and branch back to calling code LDMIA sp!, {r0,r1,lr} MSR SPSR_cxsf, lr LDMIA sp!, {pc}^ ;------------------------------------------------------------------------------ ; After a reset, execution starts here, the mode is ARM, supervisor ; with interrupts disabled. ; Initializes the chip and branches to the main() function. ;------------------------------------------------------------------------------ AREA cstartup, CODE ENTRY ; Entry point for the application ; Reset Handler EXPORT resetHandler IMPORT |Image$$Fixed_region$$Limit| IMPORT |Image$$Relocate_region$$Base| IMPORT |Image$$Relocate_region$$ZI$$Base| IMPORT |Image$$Relocate_region$$ZI$$Limit| IMPORT |Image$$ARM_LIB_STACK$$Base| IMPORT |Image$$ARM_LIB_STACK$$ZI$$Limit| ; Perform low-level initialization of the chip using LowLevelInit() IMPORT LowLevelInit resetHandler
and that will be my scatter-loading file:
Load_region 0x10000000 0x4000000 { Fixed_region 0x10000000 { *.o (VECTOR, +First) *(cstartup) .ANY (+RO) } ; Relocate_region +0 { Relocate_region 0x300000 0x10000 { ether.o (+RW +ZI) } SDRAM 0x20000000 0x1000000 { .ANY (+RW +ZI) } ARM_LIB_HEAP 0x312000 EMPTY 0x1000 { } ARM_LIB_STACK 0x314000 EMPTY -0x1000 { } }
Howard
SVC_Stack_Size EQU 0x00000008 ... ; Branch to interrupt handler in Supervisor mode */
Apparently, interrupt handlers are run in Supervisor mode, and only 8 bytes are allocated for Supervisor mode stack. If you have any interrupt handlers at all, 8 bytes would not be enough. The straightforward solution is to increase Supervisor stack size. Another solution is to run the interrupt handlers in User or System mode (shares stack with main program, saves memory.) I could be missing something, of course...
thank you for the hint. I was always looking at the last definition in the startup file
where the interrupts are disabled in the supervisor mode. I've one question about the supervisor mode: in which mode will be the lowlevelinit function called in the startup file?
The definition of the user mode (at the end of the startup file)
will allow all kind of interrupts (in the user mode). I'm starting the main function in the user mode, when a interrupt occurs the irqhandler in the startup file will be executed and will change the original settings of the supervisor mode (interrupts disabled)? And all the values of the interupt (+ jump back addr) will be stored in the SVC_Stack_Size?
Could you explain me the above part a little bit?
So if I will replace the line above with
; Branch to interrupt handler in Supervisor mode */ MSR CPSR_c, #ARM_MODE_USR
the interupts will be executed in the user mode?
I've changed the size of the supervisor stack to 0x100 and the same error occurs.
The stack size, which the processor use, starts from 0x314000 and ends at 0x313E40.
The interrupt method is very small - only checking the status registers (emac receive, transmit) and setting the value of a volatile global variable, which inidicates that a new ethernet frame received.
Too many questions, and all of them are answered in the ARM Architecture Reference Manual. I have no knowledge of the AIC, so I'm afraid my advice could be completely wrong. All I know is that with the startup file you presented, you'll definitely overflow the Supervisor mode stack. That could explain all your troubles.
Could you please tell me which configuration I have to made to avoid supervisor mode stack overflow?
; Branch to interrupt handler in User mode */ MSR CPSR_c, #ARM_MODE_USER STMFD sp!, {r1-r4, r12, lr} MOV lr, pc BX r0 LDMIA sp!, {r1-r4, r12, lr} MSR CPSR_c, #ARM_MODE_IRQ | I_BIT
