hi I wrote a code for LPC2378 about External INT, in IRQ mode works very well but in FIQ doesn't work and when I debug this the debugger stay on "FIQ_Handler B FIQ_Handler" in startup.s
this is for FIQ source code: . . . //################################# void FIQ_Handler( void ) __irq { FIO0SET=0x200000; //set led1 EXTINT=1; //Acknowledge VICVectAddr=0; //Acknowledge j=0x0; }
int main (){ . . . PINSEL4 = 0x00100000; EXTMODE=1; EXTPOLAR=0; VICIntSelect=0x00004000; VICIntEnable=0x00004000; . . .
if write __fiq after (void) give an error that need "{" for the end of line.(I don't know why?)
but when I write this code, works very well:
__irq void int0_isr( void ) { FIO0SET=0x200000; //set led1 EXTINT=1; //Acknowledge VICVectAddr=0; //Acknowledge j=0x0; }
int main (){ . . . PINSEL4 = 0x00100000; EXTMODE=1; EXTPOLAR=0; VICIntSelect=0x00000000; VICIntEnable=0x00004000; VICVectAddr14=(unsigned long)int0_isr; . . .
I increased FIQ mode stack size in startup.s but didn't have any effect
thanks a lot. your help and this URL are useful for me: " from startup.s and add "IMPORT FIQ_Handler" before "FIQ_Addr DCD IQ_Handler"
best regards
... stay on "FIQ_Handler B FIQ_Handler" ...
Yes, it would loop there if a FIQ is generated.
You need to modify your startup file and provide a link to your external function.
Something like:
FIQ_Addr DCD MyFiqHandler
