HI i am using ARM7 LPC2106 when i read a sms by AT +CMGR = 1 command i am able to read mobile number and time and date but not able to read text of that sms ehat is the problem plz reply me...... thanks
Maybe you should spend time together: http://www.keil.com/forum/docs/thread14624.asp
The chosen processor doesn't matter. The main task is to learn the use of the AT commands.
dear Westermark if u not want to give answer than why u post answer...... if u know than only post.......:X
But Per is correct - The chosen processor really does not matter one bit!
The GSM device neither knows nor cares what processor sends the AT commands - it doesn't even know or care if it was a processor at all, or someone typing manually at a terminal!
The only things that matter are that you send the correct AT commands, and your serial interface is correctly connected & configured.
www.keil.com/.../search.asp
Indeed, but as he knows perfectly well the OP just wants a "Here's the source code to do what you want" answer. I don't understand why otherwise intelligent people seem to enjoy giving these lobotomised SMS kiddies deliberately unhelpful answers. A better policy would be to ignore them.
While I'm at it, could you also refrain from posting to dead threads for no reason other than to point out that they are dead?
It isn't impossible that these two requesters are actually students at the same school in which case they may potentially meet in person. But they may join forces electronically too.
On the other hand, it would help if any discussion about line terminations, timeouts or waiting for prompts did not have to be duplicated in separate threads.
Of course, it would be even better if the forum search system was used, since there are a large number of older threads already covering the subject.
Lobotomy defined:
Surgical incision into the frontal lobe of the brain to sever one or more nerve tracts, a technique formerly used to treat certain mental disorders but now rarely performed.
or
surgical interruption of nerve tracts to and from the frontal lobe of the brain; often results in marked cognitive and personality changes
So, it that what you meant, Jack?
HI all When i run My AT command for read sms i have getting only phone number date time but not data but when i run my At command through Hyper terminal i get whole sms what is the problem
plz reply
There is a bug (or bugs) in your code - so you need to de-bug it!
Debugging is a very important part of the development process:
Debugging is detective work: you have to examine the evidence before you, and draw conclusions from it.
So, what does the evidence tell you:
Is the modem receiving your command?
Is the modem responding correctly?
Is the response reaching your microcontroller?
Is your software correctly handling the response?
From that evidence, you should be able to decide where you need to look more closely to narrow-down what is actually going wrong...
Scientific approach to debugging: www.8052.com/.../118587
www.8052.com/.../120313
I've no idea whether you are replying to my post as you failed to quote any content, but assuming you are, so what? Any response to the OP just prolongs a pointless thread.
Indeed it is, Tamir, indeed it is. I can think of no other explanation for the SMS generation.
Jack: Why are you reading posts on this forum if you are so irritated with everything?
You are not here to help, and you don't need any information from the forum...
Not necessarily - he has at least got as far as sending the correct AT command, and receiving and recognising the first part of the response. And his reply in the thread that Per linked shows that he has identified a valid approach to the problem.
So there is hope...
The only plausible answer I can come up with is that I enjoy being irritated. Strange, but apparently true.
I certainly don't have the time or the inclination to offer a free help service to all comers, but I think I have helped improve things by challenging received wisdom and groundless opinion.
Perhaps, but his reply to that post was:
Showing that he is really only interested in a direct answer such as:
Here is the source code to do exactly what you want. Give me your email address and I will send you the complete final year project that I have designed, documented and tested for you in the electronic format of your choice. If you give me your postal address I will also send you a large cheque to ensure that you will never have to consider anything as demeaning as employment. This is your right because the world owes it to you.
Not really.
Lobotomized?
Jack: this is not meant as an offense but as a joke!!!
"Not really."
Sadly, it appears that you were right.
