I start uVision3 and clicked 'New uVision Project' from the Project Menu. A 'Create New Project' window appears. I enter the name of the project (LEDTest) and clicked save. Then a "Select device for Target 1' window appeared. I then double-clicked on Atmel and chose the AT89C55WD as the device and I clicked OK. Then a window saying 'Copy Standard 8051 Startup Code to Project Folder and Add File To Project' appeared and I clicked yes. As soon as I did that, the Project Window displayed. On the 'Target 1' folder are 3 red dots which I know means there's something wrong. I haven't even written code yet and I'm having problems. Does anyone knows how to correct this problem?
what makes you so sure there is something wrong? start writing your code, uVision is waiting!
Who told you that?
That's not what they mean - see: http://www.keil.com/support/man/docs/uv3/uv3_ca_filegrp_att.htm
Try starting from here: http://www.keil.com/support/man/docs/uv3/uv3_ex_hello.htm
Tamir, I wrote some simple code to make an LED blink on and off. I tried to build it but I get 2 errors that to me don't make any sense. Here are the code and the error messages.
01 d: clr p3.1 ;Turn on LED 02 acall Delay ;Half second delay 03 setb p3.1 ;Turn off LED 04 acall Delay ;Half second delay 05 sjmp d ;Start over 06 Delay: mov r1,#255 07 b: mov r2,#255 08 e: djnz r2,e 09 djnz r1,b 10 ret 11 end
Build target 'Target 1' assembling STARTUP.A51... assembling LEDTest.a... F:\LEDTest.a(7): error A8: ATTEMPT TO DEFINE AN ALREADY DEFINED LABEL F:\LEDTest.a(9): error A46: CODE-ADDRESS EXPECTED Target not created
Andy thank you for that link. So those red dots represent a group of specific options. The color red usually represents a warning. So I assumed that 's what it was. Also I only purchased the A51 kit. So I can't use the 'Hello' project which is written in c language. I still can't see anything wrong with the code I wrote. It's just too simple not to work. I must be lousy at programming since I can't even get an LED to blink. Did you find out what is wrong with the code I wrote?
I changed the label 'b' to an 'f' and the error mesages are gone. But 3 warnings poped up. here is the contents of the output window:
assebling LEDTest.a... linking... *** WARNING L5: CODE MEMORY SPACE OVERLAP FROM: 0000H TO: 0002H *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_START MODULE: STARTUP.obj (?C_STARTUP) *** WARNING L2: REFERRENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C_START MODULE: STARTUP.obj (?C_STARTUP) ADDRESS: 001DH Program Size: data=9.0 xdata=0 code=34 :LEDTest" - 0 Error(s), 3 Warning(s)
That's the trouble: don't assume - find out for sure!
Writing software requires that you play precisely by the rules: the tools won't give you any leeway at all. They will do precisely what you say in your source code - they will not attempt to work out what you meant
Therefore the first thing you must do is to study the manuals carefully - so that you know what the rules are!
"It's just too simple not to work"
No that is not true at all, I'm afraid.
Writing a "simple" program requires just as much care, attention, and precision as writing a complex one!
Speaking of care & attention, did you not notice the instructions on how to post source code? They are clearly stated immediately above the window where you types your message...
www.danlhenry.com/.../keil_code.png
" Did you find out what is wrong with the code I wrote?"
The Assembler told you two things that are wrong with it - so fix those first!
Your first step should be to look-up those error messages in the manual: http://www.keil.com/support/man/docs/a51/a51_a8.htm http://www.keil.com/support/man/docs/a51/a51_a46.htm
and be sure to see the linked knowledgebase articles...
You need to understand why - follow the links for the descriptions of the original error messages...
I read the contents of the link file (LEDTest.lnk) and it shows zero errors and zero warnings. This is confusing. I compiled this program using an 8051 homemade compiler that I made using Visual Basic. I compared the Link file with HEX code and 2 addresses in the Link file had wrong data. I guess those are the addresses that are causing the problems.
I finally found the problem. I tried removing the file STARTUP.A51 and the program compiled perfectly. I don't know why but there is something about that file that was causing the problem.
" I don't know why "
Because this is the startup code for a 'C' program; so it expects to have a 'C' program to jump into - but you haven't provided one!
That explains it. I'm such an idiot. I thought that since it had an A51 extension that it was assembly. Are there any other files that I could add to group 1 that would give me other features that I don't know about? Do I have to put an INCLUDE file at the beginning of my code or does uVision3 do it automatically since I selected a device when setting up the project? I have a lot to learn.
"I thought that since it had an A51 extension that it was assembly."
Yes, it is assembly - you can open it and look it at - and that is why it has the A51 extension.
But its specific function is to prepare the system to run a 'C' program, and then to call that 'C' program.
"Are there any other files that I could add to group 1 that would give me other features that I don't know about?"
If you add any random file to any group you will most probably get features that you don't know about!
"Do I have to put an INCLUDE file at the beginning of my code"
No, you don't have to - but it is usually a good way to proceed.
"does uVision3 do it automatically"
Not automatically - but it does give a menu item to make manually adding the "standard" processor include file a one-click operation!
"I selected a device when setting up the project"
That's how it knows which include file to offer in the menu option. (also how it knew which startup file to offer).
"I have a lot to learn."
Indeed. And it would probably be a lot more effective if you were to take some time to sit down and do some study rather than just stumbling from error to error.
