my interrupt not back
HI.
I have a peroblem in usart interrupt . the interrupt when occure it not back and at the end of IRQ_handler function program jump to the undef_irq label in start up. it's means that the interrupt can't go back to main..whye?
in main I have a correct program. I think my problem is from the startup code.
; Setup Stack for each mode
        LDR     R0, = |Image$$ARM_LIB_STACK$$ZI$$Limit|
;  Enter IRQ Mode and set its Stack Pointer
        MSR     CPSR_c, #ARM_MODE_IRQ:OR:I_BIT:OR:F_BIT
        MOV     SP, R0
        SUB     R4, SP, #IRQ_Stack_Size
; Supervisor mode (interrupts enabled)
        MSR     CPSR_c, #ARM_MODE_SVC | F_BIT
        MOV     SP, R4
; Enter the C code
        IMPORT  __main
        LDR     R0, =__main
        BX      R0
loop4
        B       loop4
       END
IRQ_Handler
; Save interrupt context on the stack to allow nesting */ SUB lr, lr, #4 STMFD sp!, {lr} MRS lr, SPSR STMFD sp!, {r0,r1,lr}
; Write in the IVR to support Protect Mode */ LDR lr, =AT91C_BASE_AIC LDR r0, [r14, #AIC_IVR] STR lr, [r14, #AIC_IVR]
; Branch to interrupt handler in Supervisor mode */ MSR CPSR_c, #ARM_MODE_SVC STMFD sp!, {r1-r4, r12, lr} MOV lr, pc BX r0 LDMIA sp!, {r1-r4, r12, lr} MSR CPSR_c, #ARM_MODE_IRQ | I_BIT
; Acknowledge interrupt */ LDR lr, =AT91C_BASE_AIC STR lr, [r14, #AIC_EOICR]
; Restore interrupt context and branch back to calling code LDMIA sp!, {r0,r1,lr} MSR SPSR_cxsf, lr LDMIA sp!, {pc}^
above I write several line in my start up file
can you help me?? pleas!
