the problem i ask yesterday hv solved, the now i'm facing another prob. which is the velocity value cant display in LCD once i reach "START==0 AND STOP==0" it will display 255 for the velocity value, could anyone help me with that, thanks alot
#include <AT898252.H> #include <stdio.h> #include "LCD.c" unsigned char pulse_low=0,pulse_high=0; unsigned int overflow_count=0,int_count=1,pulse=0,time=0; unsigned int velocity=0; unsigned long int pulse_width=0; unsigned char b; sbit START=P1^0; sbit STOP=P1^1; char buf[16]; void main(){ lcd_init(); lcd_puts("The Speed Is"); msdelay(1000); TMOD=0x90; TF1=0; IT1=1; IE=0x8c; while(1){ unsigned char a; // unsigned char x; if(START==0&&STOP==1){ a=0; } else if(START==1&&STOP==0){ a=2; } else if(START==1&&STOP==1){ a=3; } else if (START==0&&STOP==0){ a=1; } switch(a){ case 0:{ TR1=1; break; } case 1:{ pulse_low=TL1; pulse_high=TH1; pulse=(TH1<<8)+TL1; pulse_width=(overflow_count)*65536+pulse; time=pulse_width/13921583; velocity=(180/time); lcd_gotoxy(0,1); lcd_putchar(' '); sprintf(buf,"%u",v); lcd_puts(buf); break; } case 2:{ TR1=0; TH1=0x00; TL1=0x00; overflow_count=0; break; } default:{ break; } } } } void timer1_int()interrupt 3 { overflow_count++; }
Providing clear, descriptive comments would help you as much as anyone else!
"LCD .. will display 255 for the velocity"
Look carefully at your code - what are you actually passing to the LCD to be displayed...?
actually the v is the velocity and it is wrongly written in this post, the actual code is written as velocity...sorry for the wrong info...
