I have problem in using isr_evt_set interrup handler sent event to task with isr_evt_set but task did not receive event or consumed much time
LM3S Luminary chip has NVIC and I didnt enable interrupt in user mode
at NVIC How do I set irq-handler with keil rtx is it reserved sections for nvic handler? does it need irq stack?
at startup code
export __Vectors __Vectors ... dcd irq1handler dcd irq2handler ...
at task
void irq2handler(void) __irq { isr_evt_set(INT_SIGNAL, handler_task); } __task void handler_task(void) { while(1) { os_evt_wait_or (INT_SIGNAL, 0xffff); do_start_handler(); } }
irq2handler work with privilege mode but do_start_handler is not working
help me..
I cleared my problem I missed to clrear inttrupt at handler my probelm is in usb0device interrupt
it is read USB_INT_STATE & USB_INT_STATE_ENDPOINT to completely clear at handler but I cleared just USB_INT_STATE
thank you
thank you for reply Of course i used OS_TID and created it in init_task. And I have read state-bit for irq-clear in handler Sample code is conceptional code.
Problem is handler do not send signal and task do not receive signal completely (some time receive it)
the 2nd parameter to isr_evt_set needs to be the Task ID (returned from some from of os_tsk_create) of the task you want to send the event too, not the address of the function you want to send it too.
