Accessing application section from boot program
I am working with Atmega128 and i want to write a program that enters the boot section when a particular pin is low and after executing boot program looks in the application area of Atmega128. If some program is present there i want to erase it.
Up till noe i have managed to cause the program to enter in boot section and execute the code. But further i have no idea how can it make a search for the presence of some code in application area and then to erase it.
Thanks in advance.
  • hopefully you forced your program into boot using the watchdog reset.
    you can write a specific location in flash with a code indicating that the program at a specific location was programming successfully (either by IAP or JTAG - use absolute positioning of the code) after you verified its checksum. you can erase Flash by IAP commands. consult your processor manual.
