hay Iam working on infineon XC866 micro controller.I am facing difficulty to understand the ADC & Capture/Compare Units because of the huge registers. Please provide any tutorial or example programs to understand the infineon controller
Thank you, Regards naresh
There is a setup program (GUI) you can use called DAvE that can guide you through the peripheral setup. Have you tried this? You can import a DAvE project directly into Keil tool environment.
