SiLabs F340 EMIF for External Device Access
I am using the uVision 3 (ver. 3.72) tool and working with a Silicon Labs 8051F340 MCU. I need to map a device (an FPGA with registers) into external memory and access it with the MCU. There are not very many FPGA registers to access.
I am trying to use Split Mode without Bank Select and a multiplexed address/data bus. I'm looking for some guidance in setting up the target options, startup assembly code, and anything else that's necessary.
I have code compiling which is basically:
volatile uint8_t xdata *fpga_reg = (volatile uint8_t xdata *)0x1000;
*fpga_reg = 0x12;
Thanks in advance for any help.
