Dear All,
When I am compling the c program below i am getting the error
"""error C211: call not to a function"""
Can anyone help me out with this error ?
/**************C FIle*************/ #include "abc.h"
extern unsigned char func_arry_pntr; extern unsigned int xdata *funcArr[32];
void timer1_routine(void) interrupt T1_INT using 3 { static unsigned char intr_counter;
++intr_counter; if(intr_counter == 0x0A) { intr_counter = 0x00; (*funcArr[func_arry)pntr])();
if(func_arry_pntr < MAX_ARRAY_SIZE) { ++func_arry_pntr; } else { func_arry_pntr = 0x00; }
/*********** array define *******/
xdata unsigned int (*funcArr[32]) = {&func1, &func2, &func3, &func4, NULL, NULL, NULL, NULL};
I don't know what you thought with:
A type declaration of a function pointer looks like:
typedef return_type (*type_name)(parameters);
"func_arry_pntr" is defining the index of an array funcArr[] of function pointers.
I am incrementing the array index when intr_counter equals to 0x0A, so that program run next function.
so all its doing is running function func1, func2 etc whenever i am incrementing the array index func_arry_pntr
Did you read my post about a type declaration of a function pointer?
This is an array of 32 pointers to unsigned int. Not an array of 32 function pointers.
Thanks Mark for your help. I corrected the declaration of function pointer using typedef and its compling the program without any errors :)
thanks again
