I'm using ARM MDK to develop TMS470 applications.
Everything works in debug mode with ULINK2. I burn the image into internal flash. But it just can't work.
Anyone has exp on such case?
No,
I just type in the code and let other people test it.
Minkey.
How do you know that?
I have leds turned on to show the function present
this issue fixed.
the problem is from startup code.
To make it run standalone, we have to init the RW, ZI with the right memory map. Usually, it is done by the runtime lib __main. But our project have to be done by ourselves.
I guess in debug run. The host/debugger init the RW, ZI regions even without the keil runtime init __main. That's why we can run without right startup.
Huh? What kind of argument is that supposed to be? What does you doing your own project have to do with letting the compiler do its job?
